Crome P30/P72 base maps - reliable/accurate enough to run a stock car on?
Old Jan 14, 2009 | 01:32 PM
Captain_Sl0w's Avatar
Default Crome P30/P72 base maps - reliable/accurate enough to run a stock car on?
Has anyone ever ran a Crome base map on their car for a stock/relatively stock B16 or B18C? From people's experience, are they accurate enough for me to reliably run my car on?
Old Jan 14, 2009 | 02:26 PM
should be fine if the tuning company you get your base map from is reputable. base maps are usually rich, so you definitely won't lean out.
Old Jan 14, 2009 | 03:26 PM
i was on about the Crome maps, not a tuning company's maps
Old Jan 14, 2009 | 04:31 PM
oh, not sure then
i don't think i would risk that though then
Old Jan 15, 2009 | 10:26 AM
bcivic's Avatar
Do you mean the stock roms in crome if you do they wont run the car as well as the stock ecu wil becuase it is a modded ecu but it will be close you could just get a wideband and make adjustments from there but most actual basemaps are made by people or companies and they can be ok but unless it is a close to stock engine they too wont be perfect until properly tuned.
2014HondaEX-L
Apr 16, 2015 07:04 PM
Captain_Sl0w
Aug 19, 2008 06:41 PM
selvan777
Nov 13, 2007 06:05 AM
TimThein
Sep 4, 2007 12:33 PM
