vacuum leak
Old Feb 2, 2009 | 09:18 AM
texasmade's Avatar
Default vacuum leak
i think i might have a vacuum leak im idoling at 1500 it will move up or down just a little bit i checked my intake made sure everything was tight..so maby the manafold gasket?
Old Feb 2, 2009 | 09:36 AM
Test for an intake air/vacuum leak by placing your hand over the top of the throttle body to see whether it kills/chokes the engine. If the engine continues to run, then you definitely have a leak.
Have you already cleaned the IACV and FITV (see links in my signatures)?
Old Feb 2, 2009 | 09:50 AM
texasmade's Avatar
no i have not checked them yet i guess i should start with iacv first huh ?
Old Feb 2, 2009 | 10:16 AM
If you have a 5th generation Civic, start by testing and cleaning the FITV.
Old Feb 2, 2009 | 07:21 PM
texasmade's Avatar
alrite thanks for ur help
Old Feb 3, 2009 | 05:49 AM
bcrichguitars's Avatar
Do you mean to take the intake off and cover the inlet of the throttle body?
Old Feb 3, 2009 | 05:59 AM
With the air cleaner intake removed, block the entire main hole of the throttle body with your hand. If the engine either continues to run normally or chugs but doesn't die, then you have a major intake air leak. By the way, this test won't reveal a minor intake air or vacuum leak.
jockellis
Mar 1, 2014 01:00 PM
skyclimber
Jan 24, 2012 10:52 AM
atlantahonda
Jun 26, 2011 07:00 AM
dustinwithanx
Nov 21, 2009 09:29 PM
xonic
May 26, 2005 04:58 PM
