EK Swaps 1996-2000 Civics
T/c a B18C?
Old Jul 11, 2005 | 09:42 AM
CallawayCrazy3's Avatar
Default T/c a B18C?
I have a 97 DX 2 door coupe and I am going to be putting a t/c in it. I just wanted to know if the B18C Type R engine was a good engine to do this to? I was doing some research and I thought some where I read that this was not a good idea. If what would be the best engine to do this to, to get the most power out of?
Old Jul 11, 2005 | 10:18 AM
Pete's Avatar
Default RE: T/c a B18C?
B18C5 is a bad motor to boost.......compression is too high. U can put a B16 head on it and it will lower the compression to handle the boost. However if ur really going to turbo ur car just get a B16 and ud be very happy. Turbo on a B18C5 would be some $$$$ pit....consdering the motor is over 4 grand alone........
Old Jul 11, 2005 | 03:31 PM
polo708's Avatar
I boosted my b18, straight up...
Old Jul 11, 2005 | 05:08 PM
Pete's Avatar
im sure if u run low boost it wont be a problem........but from what ive heard polo the b18c5 is a bad one to boost cuz of the compression. How many PSI were u runnin on ur motor.......was it a GSR or type R........
Old Jul 11, 2005 | 05:43 PM
LEVIII's Avatar
Its not bad, you just have to keep the boost at sane levels. nothing crazy. Id think a B18C1 with a B16 head swap would be the best DOHC VTEC motor for boost
Old Jul 12, 2005 | 12:23 AM
b16 head will only lower the compression on a GSR, not a type r. the type r and b16 heads are the same casting.
go with a GSR motor for boost.
Old Jul 12, 2005 | 11:41 AM
polo708's Avatar
mine was a swap from a US spec GSR, had soem internal work done too.
Old Jul 12, 2005 | 02:31 PM
Pete's Avatar
nice......i wish i had time and money for a swap......im going to boost the d16 @ 6psi and call it a day.
legal
Jan 26, 2008 09:35 PM
DenkiEx
EK Swaps
Apr 24, 2007 10:07 PM
98brokeassvtec
Mar 15, 2005 10:58 PM
DenkiEx
17
Feb 3, 2005 09:31 PM
Druvochsky
Dec 10, 2004 05:51 PM
