97 civic lx sedan auto trans issue
Old May 8, 2009 | 03:56 AM
xpdude's Avatar
Default 97 civic lx sedan auto trans issue
transmission won;t engage into gear or slips and jerks after warm. do these trannys fail often? what kind of trans does this model carry, in case i need a replacement. the fluid is bright red. i hear their is a cvt transmission and a different one that they could have.
Old May 9, 2009 | 03:41 AM
xpdude's Avatar
Default transmission bad?
i hear this is a common problem? how do i know what kind of transmission is installed? i know its a 4 spd auto but what is the name of the transmission?
Old May 9, 2009 | 04:42 AM
You should be able to figure it out using your VIN and the diagram below.
Is the CEL ON or is the D4 light blinking?
Old May 10, 2009 | 11:22 AM
CivicSi99's Avatar
I acually just read about this problem, It also most common with the 97's. I would just replace it, maybe a new one or even used if you don't think you can afford a new one. If I was going to replace one I would put in a 5 speed manual. There pretty durable and I heard they last forever. They are also fun to drive and get pretty good gas mileage. But again the CVT also gets very good gas mileage and is very good if that's all our really looking for (as in no power upgrades.) If this is just your daily driver then a CVT would probably be great for you. If you need anymore info on the CVT just ask.
Old May 11, 2009 | 03:09 AM
xpdude's Avatar
Default 97 civic transmission
will the cvt fit my model? i think i just have a 4 spd. don't they have the cvt in the newer 00-02 models? how hard is it to switch to a 5 spd manual?
Old May 15, 2009 | 03:59 AM
xpdude's Avatar
Default ok this is just wierd
now the trans is working fine. it is OVERFILLED. does honda fluid make any difference? looks like the p/o put in penzoil tranny oil.
Old May 15, 2009 | 07:03 AM
Use Honda or Honda recommended tranny fluid.
Old May 15, 2009 | 08:21 AM
xpdude's Avatar
Default 97 civic
how hard is the tranny to replace on these and if it dosn;t have a cvt but a 4 spd, will a cvt fit?
Old May 26, 2009 | 04:13 PM
xpdude's Avatar
Talking transmission question
heres what i got. i found i have got the B4RA 4 speed. arn;t they suposed to last for a long while? what is the difference between a cvt and b4ra and will they interchange w. a base model civic lx engine?
Old Jun 5, 2009 | 10:38 AM
xpdude's Avatar
Talking tranny issue cont..
ok guys i have a b4ra transmission, and would like to swap a cvt in. is this possible?
mudhenFUF
Jan 16, 2023 08:43 PM
accordian
Oct 2, 2009 08:37 PM
succafooschnookem
Oct 29, 2008 08:47 PM
bonzitre
Jan 21, 2007 08:51 PM
Lordnismo
Sep 26, 2006 03:07 AM
