$229.04 to install my exhaust system....
Old May 20, 2009 | 06:09 AM
enigma34's Avatar
Default $229.04 to install my exhaust system....
Is 229.04 worth it? I made an appointment for 9:30am today to have my exhuast system installed. I get ther and they say it will take at lest 3 hours for the cat to cool down for them to start... It was only a 5 min drive to these place... So i made an appointment on friday.
Old May 20, 2009 | 06:25 AM
Oh god... no it is not worth it. The hardest part of installing an exhaust kit (I am assuming cat-back) is getting the stock exhaust system off. It has been on there for about 10 or more years untouched most likely.
What kind of exhaust system did you buy? j/w Also, if you drive the car, the exhaust system will get hot, fast. It would need to cool down a little prior to the tech's working on the car.
Old May 20, 2009 | 06:31 AM
enigma34's Avatar
Unhappy
hhhhh..i have megan herader,magnaflow cat, and a spec D cat back.. idk....
i think i was charge by the hour, 3 hours of work i think...
Old May 20, 2009 | 07:33 AM
Engelhonda37's Avatar
its definitely not hard to install an exhaust and it'll save you alot of money doing it yourself. 230$ to put an exhaust on is way expensive to me. in my opinion do it yourself, working on your own car helps you learn alot about it and i mean come on, i was 17 when i installed my exhaust! =)
Old May 20, 2009 | 07:42 AM
Is your cat built "into" the header? If not, look below
For the stock header, I believe there are nine nuts on the top that you can see, one from a bracket connected to the block, and two spring bolts to the cat. From the stock cat, there should be three nuts which connects the cat to the b pipe. There will be two spring bolts connecting the b pipe and remaining exhaust pieces at the rear pass. axle. Oh yea, you have the two o2 sensors as well to remove and swap over to the new header and cat.
Most likely, you will have to get new bolts for where the b pipe meets the axle back, and where the cat meets the b pipe. Reason: The magnaflow cat most likely does not have those studs sticking out that the OEM cat has, and the new b pipe will most likely not have the nut already on it that will accept the spring bolts.
I hope that helps. If you want, I can go snap some pics (of my car) of exactly what I am talking about.
Old May 20, 2009 | 10:48 AM
enigma34's Avatar
cat biult in header. and i dont have jacks. i need to buy them car ramps.
Old May 20, 2009 | 11:19 AM
jprommel's Avatar
Angry Admin
dont be a ***** do it yourself /thread
*find someone w/ jacks or ramps.
Old May 20, 2009 | 11:22 AM
danomatic93's Avatar
June 2010 ROTM
Holy crap where are you located!? I could probably drive to you, install it all and drive back while still running a profit off of that price!!!
Please get a second quote, somewhere else.
Old May 20, 2009 | 12:45 PM
enigma34's Avatar
ok lol, i decided to do it myself. i just bought some napa ramps for $55.
These leves me with $174.04
Old May 20, 2009 | 01:00 PM
lowlife9's Avatar
Banned
yes its extremely easy unless the ols exhaust is rusted together and you have to cut it.also get that mechanical o2 simulator .
