Auto Transmission part numbers?
Old May 23, 2009 | 09:55 PM
GregStarr's Avatar
Default Auto Transmission part numbers?
I recently purchased a used a/t for my 1989 civic 4 door dx sedan. After I installed the used a/t I discovered that it requires 27 spline inboards. My original required 25 spline inboards. I don't want to remove the transmission that I just installed so I need to know what car it came from so I can get the correct seals and inboards to finish the installation. Does anyone out there know how I can ID the used tranny so I can figure out what model vehicle it came out of to enable me to buy the correct parts for it. The company I purchased it from has been no help and only want to give me a refund.
Thanks in advance,
Greg
Old May 24, 2009 | 02:48 AM
jprommel's Avatar
Angry Admin
there should be a VIN number somewhere on the transmission then just look up a iste that decodes them and you can figure it out
Old May 24, 2009 | 09:29 PM
GregStarr's Avatar
What is an "iste" and where do I find it?
Old May 24, 2009 | 09:35 PM
jprommel's Avatar
Angry Admin
lol sorry ifail i meant site. typing owns me
http://www.autohausaz.com/honda-auto...n-numbers.html
Old May 25, 2009 | 08:36 AM
GregStarr's Avatar
Thanks for the site above, but I need to decode the number off the transmission, not the car.
The numbers off the transmission are ML4A-6240021
What a nightmare this has become.....I now wish I would have just had my original transmission rebuilt!
HELP....
Old May 25, 2009 | 09:11 AM
jprommel's Avatar
Angry Admin
there should be a VIN plate on the transmission. the vin will tell you what yr and model car it was in originally.
Old May 25, 2009 | 08:02 PM
GregStarr's Avatar
VIN is vehicle identification number.......I need to decode the number for the transmission not the car. I know what car I have, but what I need to know is what car the transmission came out of.
The transmission number is ML4A-6240021
If anyone knows of a decoder for the transmission NUMBERS I would be set!
Thanks
Old May 25, 2009 | 08:31 PM
jprommel's Avatar
Angry Admin
HOLY FUСKING ****!!! how hard is it to understand the vin on the tranny will be from the one it was originally in. not your car it doesnt magically turn into your vin.
Old May 26, 2009 | 02:42 PM
GregStarr's Avatar
jprommel
please do not respond to my post anymore.
You do not understand the problem and your insulting response above is not helpful.
Thanks,
Old May 26, 2009 | 09:05 PM
[edit] I take that back.
Now that I think about it, Honda didn't start putting VINs on engines and trannys until sorta recently. Sorry, I read that you had a 1998, not 1989.
ML4A-6240021. ML4A is the transmission code, 6240021 is probably the serial number. ML4A 4 speed auto transmissions came in 1988-1991 Hondas, i believe with D15B2, D15B6, D15B7, and D16A6 engines. Those came in the Civics and CRXs of that time. There is mention of a CRX over at Honda-tech with a D15B2 and a "stock" ML4A transmission.
Can any of you EF guys add anything to that?
Fiirkan
Jan 31, 2010 06:58 PM
Myk
Oct 25, 2008 01:09 PM
98civex
Mar 14, 2007 08:19 AM
jim9418
Dec 16, 2005 02:01 PM
