Auto Transmission part numbers?
I recently purchased a used a/t for my 1989 civic 4 door dx sedan. After I installed the used a/t I discovered that it requires 27 spline inboards. My original required 25 spline inboards. I don't want to remove the transmission that I just installed so I need to know what car it came from so I can get the correct seals and inboards to finish the installation. Does anyone out there know how I can ID the used tranny so I can figure out what model vehicle it came out of to enable me to buy the correct parts for it. The company I purchased it from has been no help and only want to give me a refund.
Thanks in advance,
Greg
Thanks in advance,
Greg
Thanks for the site above, but I need to decode the number off the transmission, not the car.
The numbers off the transmission are ML4A-6240021
What a nightmare this has become.....I now wish I would have just had my original transmission rebuilt!
HELP....
HELP....
VIN is vehicle identification number.......I need to decode the number for the transmission not the car. I know what car I have, but what I need to know is what car the transmission came out of.
The transmission number is ML4A-6240021
If anyone knows of a decoder for the transmission NUMBERS I would be set!
Thanks
Thanks
[edit] I take that back.
Now that I think about it, Honda didn't start putting VINs on engines and trannys until sorta recently. Sorry, I read that you had a 1998, not 1989.
ML4A-6240021. ML4A is the transmission code, 6240021 is probably the serial number. ML4A 4 speed auto transmissions came in 1988-1991 Hondas, i believe with D15B2, D15B6, D15B7, and D16A6 engines. Those came in the Civics and CRXs of that time. There is mention of a CRX over at Honda-tech with a D15B2 and a "stock" ML4A transmission.
Can any of you EF guys add anything to that?
Myk
Oct 25, 2008 01:09 PM
jim9418
Dec 16, 2005 02:01 PM
1989, auto, civic, find, h22, honda, ml4a, ml4a6240021, number, numbers, part, serial, spline, transmission, transmissions
