bigger cam
Old Jul 6, 2009 | 02:35 PM
jeff115's Avatar
Default bigger cam
are they worth it? i tried to search but couldnt find anything. so would a bigger cam and some porting give a noticeable gain?
Old Jul 6, 2009 | 03:15 PM
ej6buddy's Avatar
Whether it's worth it depends on what previous upgrades you have and what deals you can find. You'll be needing a cam(s), upgraded valvetrain, tuning, injectors, etc.
Old Jul 6, 2009 | 03:22 PM
I have a stage 2 crower camshaft in my d16y8 with valve springs/retainers, IM, no porting done though. After a quick base tune, the car was a little faster with the butt dyno, but really not that huge of a difference.
Old Jul 6, 2009 | 04:19 PM
jeff115's Avatar
ok i gues i wont do it. then
Old Jul 11, 2009 | 04:11 PM
riceburner700's Avatar
did you degree the cam in with dial indicator and a crankshaft degree kit? probably the reason you didnt make that much more power
Old Jul 14, 2009 | 06:12 AM
^^ Are you talking about advancing the timing?
Old Jul 14, 2009 | 02:09 PM
not distributor timing but with a cam gear to get the cam dialed into the bottom end perfect (mechanical timing)
Old Jul 14, 2009 | 06:10 PM
ej6buddy's Avatar
ditto, you can't just throw stuff on the car and hope it works.
Old Jul 15, 2009 | 06:02 AM
plethoric33's Avatar
From everything Ive read, building and port and polishing the head is really where your going to make power. I personally havent started building mine, but I have read threads on HT comparing dyno runs with diff cams and the difference was pretty big in a few cases.
Old Jul 15, 2009 | 06:12 PM
ej6buddy's Avatar
^ depends on the person that does the headwork. Take a diy kinda guy and let him port and polish his head and compare the gains to a professional doing the port'n'polish, the results will be tremendously different.
hatch46580
May 8, 2008 08:42 PM
dustin_crxsi
Jan 26, 2007 12:59 PM
civicblend97
Apr 29, 2006 01:12 AM
Pete
Oct 13, 2005 11:32 PM
Dickie
Jan 16, 2005 05:56 PM
