bigger cam
I have a stage 2 crower camshaft in my d16y8 with valve springs/retainers, IM, no porting done though. After a quick base tune, the car was a little faster with the butt dyno, but really not that huge of a difference.
did you degree the cam in with dial indicator and a crankshaft degree kit? probably the reason you didnt make that much more power
From everything Ive read, building and port and polishing the head is really where your going to make power. I personally havent started building mine, but I have read threads on HT comparing dyno runs with diff cams and the difference was pretty big in a few cases.
