sound detining cause rust??
Old Jul 19, 2005 | 07:33 PM
mill$civic's Avatar
Default sound detining cause rust??
ok,im just about to put some dynamat down in my trunk and so on and then i was just thinking, does this cause rust? the reason why i am questioning this is because if u ever leave like a carboard box in your trunk or where the spare wheel is, is will become soggy from the mosture i guess, so if i put dynamat on my trunk lid and down where my wheel well is and so on, will mosture get trapped inbetween the metal and the dynamat and create rust??? comments? findings? thanks
Old Jul 20, 2005 | 12:13 PM
Remmy's Avatar
Default RE: sound detining cause rust??
No. It does not cause rust. Dynamat only absorbs vibration. All it is is aluminum and a sticky rubber compound. Last time I checked, those 2 dont absorb moisture.
Old Jul 20, 2005 | 12:17 PM
GSRDevil's Avatar
Never heard of it causing rust. In fact if you get it sealed up against whatever you're mounting it on real good without any trapped air or moisture it should prevent rust
Civic Si 00
Feb 26, 2008 06:22 PM
cbaber
Jan 17, 2008 12:26 PM
sparkie
Oct 13, 2007 08:18 PM
cinefyl
May 21, 2006 12:54 PM
z6 FoRiLLa
Sep 28, 2005 03:28 PM
