e-brake light....
Old Aug 2, 2009 | 09:29 PM
my99lx's Avatar
Default e-brake light....
within these last 2 days my e-brake light has been coming on sporadically, mostly it seems when i begin to accelerate. most of the time it will go off on its own after a lil while. sometimes if i slightly lift up the e-brake (not enough to where it clicks cuz then the ebrake will make me have an accident haha) and then push it back down it will turn off the light. any ideas of why the e-brake light is coming on?
Old Aug 2, 2009 | 09:54 PM
it also comes on when your brake fluid is low.
Old Aug 2, 2009 | 11:59 PM
my99lx's Avatar
thats probably the issue then cuz my brake fluid was low when i had my rear brakes replaced. i thought they had filled it up but i guess not, i didnt check it. thanks!
Old Aug 3, 2009 | 01:36 AM
I agree. When your car changes speed or direction, momentum shifts and the brake fluid sloshes. The brake fluid is probably low enough to the point where when it sloshes sometimes the sensor reads it as too low.
Old Aug 3, 2009 | 08:25 AM
my99lx's Avatar
yea i just checked it this morning and its just above the min line so it probably dips below when i accel. thanks guys!
Old Aug 3, 2009 | 08:43 PM
gwl's Avatar
gwl
You should check your brake pads - front and back for wear. Brake fluid displaces wear not unless you have a leak.
adb
Jul 15, 2012 09:22 AM
juniorbiscuit
Oct 15, 2010 12:24 PM
gunaa
Oct 22, 2009 11:36 AM
Stumasters
Jan 17, 2007 01:36 AM
sir_nasty
Mar 27, 2006 03:09 PM
