Tachometer
Old Aug 30, 2009 | 09:59 PM
KStorms2009's Avatar
Default Tachometer
Does anyone know how or can post a DIY about wiring in a tachometer (RPM). I have a 98 dx and doesnt have a tach but need to know how to wire it into the distributor when i buy one, idk where to start...
thanx
Old Sep 1, 2009 | 01:18 PM
both in the engine bay, on the driver side near the fender wall, and behind the engine temperature gauge cluster in the dash there will be a blue wire with a white or silver stripe up it, both of these are tachometer sensor wires. You can splice into those for the tach sensor
Old Sep 1, 2009 | 04:23 PM
why dont you just buy a 96-00 ex stock cluster it has a tach built into it and will hook right up and no extra wiring is needed
Old Sep 10, 2009 | 01:57 PM
AlexDavid's Avatar
speaking of tachometers what are normal readings for when the car is in park and stopped at lights etc.?
Old Sep 10, 2009 | 02:35 PM
Between 600 and 800rpm, assuming the engine is at operating temperature and the A/C is not running. If the A/C is running or the engine is cold, it will idle higher.
Old Oct 31, 2010 | 10:54 AM
4door4me's Avatar
Default Tachometer Gauges
Need a little more info on tachometers? Visit http://thetachometergauges.com/ to gain a little more knowledge. Thanks
95dx28
Jun 14, 2005 02:37 PM
voidmain
May 18, 2005 09:22 PM
Super Mario
Oct 29, 2004 01:13 PM
ShÖgun
Aug 29, 2004 04:36 PM
civicguy1xxxxx
May 25, 2004 09:29 PM
