Clunking from Rear
Old Sep 18, 2009 | 05:40 AM
space_ace's Avatar
Default Clunking from Rear
I have a 1995 honda civic cx hatchback and when I brake a get a clunking or clicking noise coming from the rear suspension. On my protege a similar noise was caused by worn rear stabalizer links but the civic doesn't have links on the rear. Any suggestions of what this could be would be appreciated.
Thanks in advance,
Ace
Old Sep 18, 2009 | 08:55 AM
check all your rubber bushings in the rear..
Old Sep 18, 2009 | 10:37 AM
space_ace's Avatar
I get the noise under braking when the brakes are partially applied but when I fully apply the brakes the noise goes away. Don't know if this makes a difference.
Old Sep 18, 2009 | 11:20 AM
have you check the inside of your drums?
Old Sep 18, 2009 | 06:23 PM
well the common clunking noises are the bushings the 3 on the LCA, the main bushing that bolts the knuckle to the vehicle infront of the wheel.
but good luck with removing the rear suspension bolts on the LCA because they are commonly seized up!
just check em all out as good as you can... look for any cracks or if the center steel sleeves are even in the rubber bushing. if the sleeves are not even then the steel shaft has seperated from the rubber bushing and it sliding back and forth is giving you a clunk.
i had mine clunking quite a bit on my old 94 civic front strut bushings.
Old Sep 21, 2009 | 03:41 AM
space_ace's Avatar
I've checked all the bushings in the rear and they are all fine except both my trailing arm bushings have a small crack in them. I've known about them for a while but have only noticed the clunking with the cooler weather so I don't think they're the problem but they obviously need to be changed. What am I looking for on the drums and why would they clunk?
Old Sep 21, 2009 | 07:17 PM
if something was broken in there like a spring. i had it happen in my 91 hatch.
2ManyTickets
Apr 25, 2009 11:24 AM
dsilentninja
Apr 2, 2009 05:50 AM
Chandlergreg
Aug 1, 2007 03:31 PM
danomatic93
Apr 13, 2007 12:54 PM
powderdude
May 11, 2005 03:49 PM
