Diagnosing 93 civic front-end noise (video w/ audio)
Old Oct 16, 2009 | 04:44 PM
czissman's Avatar
Default Diagnosing 93 civic front-end noise (video w/ audio)
My gf's 93 Civic LX 5-speed (175,000 miles) is making a sound I immediately thought was a wheel bearing. I did a little research on the process of repairing it, slipped a jack stand under the car, and rotated the front wheel, expecting not to hear the noise because the bearing wasn't under load. Surpisingly, I did hear the noise, but now I'm not so sure it's a wheel bearing: It sounds too "regular" to be a bearing. Check out the video to hear what I hear.
My GF and I are both on tight budgets due to layoffs, so I can't throw money at this problem using the "diagnose by parts replacement" strategy, so I'd like to accuratey nail-down this problem before I start buying parts.
Question one: What do you think is causing the noise in the video?
Question two: Could this be mistaken as a wheel bearing from inside the cabin, or is it more likely that I have two problems?
Question three: Can you recommend a specific wheel bearing diagnostic procedure?
Thank you very much in advance for your help!
Chuck
(PS: The squeak you hear in the video is just my hand squeaking on the tire as I turn the wheel.)
http://www.youtube.com/watch?v=wCc_DPLCRR8
Old Oct 17, 2009 | 07:10 AM
hybred-1's Avatar
I concider myself a backyard mechanic as well. My first thought is axel. Typically I haven't had one sound quite like that but, I have had the general clunking while turning and when I did my B swap I had a similar noise right before the axel broke. (no LSD so I had to have it towed.)
Second if that isn't it I would go with wheel bearing. I think axel first, cause with my honda pilot there was no sound or anything like that when my bearing seized.
Again this is my $0.02, I am a backyard mechanic. LOL
STevo
Old Oct 17, 2009 | 09:05 AM
I'd tend to agree with hybred on it being the axle (or at least a CV joint). That's definitely not the noise a wheel bearing makes, loaded or unloaded (bearings of any kind tend to make a growling noise), nor is it a brake noise, so that pretty much leaves the CV shaft as the only plausible action.
Oh, and if we're listing credentials, I am a mechanic (subaru, honda, what's the difference? lol)
Old Oct 21, 2009 | 02:30 PM
czissman's Avatar
Hybred and Reaper: Thanks for your thoughts.
I think the noise is in the video is a red herring. The trouble is a bad outboard right CV joint. Time for an axle.
oxymoronic
Apr 27, 2013 11:55 AM
DannyHC
Jul 21, 2009 05:04 PM
Gone in 60
Feb 11, 2009 11:16 AM
GangstaMas1
Apr 11, 2008 08:57 AM
jbeynon
Apr 4, 2008 10:41 AM
