Diagnosing Blower Motor Failure
Old Apr 4, 2008 | 10:09 AM
jbeynon's Avatar
Default Diagnosing Blower Motor Failure
Hi there,
newbie here....so be gentle.
I'm currently diagnosing a fault on my 2002 civic where the blower motor isn't working. I've run the DTC check which indeed indicated a fault in the blower motor circuit. I've checked the two fuses and both are fine.
I've searched on these forums and have found this
on the blower motor there is a connector with 2 wires going to it ..a white/blue and a blue/black
chk to see if you get power with the key on at the white/blue
and ground at the blue/black
if you get both you got a bad motor
ok, so i've removed the lower kick panel and have found the connector - silly question but could you describe in simple terms how i perform these tests - i'm armed with a digital voltmeter.
many thanks,
john.
Old Apr 4, 2008 | 10:27 AM
jbeynon's Avatar
Default RE: Diagnosing Blower Motor Failure
just an update, i put the meter across the two pins of the connector and am getting 12v, odd thing is i get that even when the fan dial is 'off'
Old Apr 4, 2008 | 10:41 AM
Since you have 12 volts across the two pins yet the motor doesn't run, that means the motor is bad.
There may be a slight normal leakage in the circuit so the voltage doesn't go away with the control off.
B18boosted
Sep 23, 2011 11:13 AM
czissman
Oct 21, 2009 02:30 PM
DannyHC
Jul 21, 2009 05:04 PM
Gone in 60
Feb 11, 2009 11:16 AM
GangstaMas1
Apr 11, 2008 08:57 AM
