unique 2000 si starting issue
Old Mar 28, 2010 | 08:24 AM
20sir00's Avatar
Default unique 2000 si starting issue
I have a 2000 Civic si. I have been searcing and trying things on the car for a couple weeks and still no luck.
Ill start from the begining. about 6 weeks ago the car started developing a very bad miss. I replaced the plugs and wires and it ran great again. This lasted about 3 weeks and the miss came back. After turning the ingition over noticed the screw had come out. At this point the car still ran, just with a bad miss. So i figured i had found the issue and replaced the cap,rotor and screw. To my suprise it now would no longer start at all.
I have verified the fireing order, checked each plug for spark and they all get good hot spark, the fuel pump is engaging and injectors are opening propoperly. Upon turning key the cel comes on for 2 seconds and turns off like it should. all fuses are good.
I'm completly stumped on this right now. I have not checked the timing yet, but that seems unlikely as it still fired and ran before changing the cap and rotor. Oh and i also tried putting the old cap and rotor back on and still nothing.
Any ideas? I'd GREATLY appreciate any help
20sir00 is online now Report Post Edit/Delete Message
Old Mar 28, 2010 | 08:49 AM
Maybe somehow the rotor is on wrong. You should check the timing, make sure the rotor points at wire #1 when the engine is set to TDC1.
Old Mar 28, 2010 | 09:23 AM
U.S. or Canada Si?
Is spark bright white?
Below is the correct firing order on the distributor cap. The cylinders are ordered 4-3-2-1 from the distributor to the timing belt.
Below is also shown the correct mechanical timing for the U.S. and Canada Civic Si.
Old Mar 28, 2010 | 02:24 PM
20sir00's Avatar
Originally Posted by RonJ
U.S. or Canada Si?
canadian i believe. the plug order is definatly correct, I will check the timing next, thanks guys!
Old Mar 28, 2010 | 02:30 PM
Civic Si: US = DOHC; Canada = SOHC
Old Mar 28, 2010 | 03:38 PM
20sir00's Avatar
My bad, defiatly US. DOHC
CivicWar
Apr 6, 2008 05:55 PM
Gonzo
Mar 14, 2008 11:26 PM
DannyEG6
Dec 19, 2006 08:27 PM
Tater
Nov 30, 2006 09:27 AM
HondaBlue
Jul 21, 2006 06:00 AM
