doing a cluster swap
Old May 12, 2010 | 03:05 PM
Rellikmac's Avatar
Default doing a cluster swap
i am doing a cluster swap, i have a normal cluster that has no tach, and i am swapping it for a cluster that has a tach, is there any new wires i need to set up in order for the tach to work with the new cluster
Old May 12, 2010 | 03:35 PM
nope all 96-00 civics clusters are interchangable, no new wires to add.
simple plug and play.
Old May 12, 2010 | 03:37 PM
Rellikmac's Avatar
ok good beacuse i have a 99 civic hatch back, so it will work just plug and play thank you addiction2bass
Old May 12, 2010 | 03:44 PM
yes and if you want to keep your milage true then you can pull the cluster apart, first remove the cluster, and then turn the two upper outter bezel bulb with the wires on it so you can pull off the black bezel part if you dont the wires wont let you pull it off, now pull off the clear front bezel and the black bezel and face overlay, all of those come off with simple plastic tabs you just push over and pull the face apart... now DO NOT TOUCH THE NEEDLES OR THE SCREWS ON THE GAUGES FACE!!!!!! DO NOT!!!! youll snap the needles off really easily and they do not go back on.
now with the front of the face all opened up then look at the backside of the cluster and remove the 4 philips scews on the center section, and this will allow the speedometer section to come out the front once those screws are gone, then just pull the second cluster apart and reverse and put it back together with your stock milage still 100% correct and true! just when screwing those 4 screws back in BE CAREFULL only give them a snug fit, if you try and tighten them to hard they can break the internal wire and youll be screwed and have to use the incorrect speedometer milage section! so just be carefull to only snug the screws!
Old May 12, 2010 | 03:49 PM
Rellikmac's Avatar
thank you but i have no need to do that because i searched all over for a cluster close to my mileage this way it wasn't too far off i did not know you can correct your mileage, but thank you again for your help.
Old May 12, 2010 | 04:11 PM
If you have a K20 like in your sig then I hope you got a cluster with a tach that goes high enough
Old May 12, 2010 | 04:44 PM
Rellikmac's Avatar
the cluster goes up too 10,000 rpm's. i hope it will be enough
Old May 12, 2010 | 04:46 PM
Oh wow, you should be good then
Old May 12, 2010 | 04:53 PM
Rellikmac's Avatar
lol, yeah i hope so, i paid almost 300 for it it came from japan, ill post pic's in my garage after i do the swap and show you, i also bought a steering wheel from password jdm for like 650, the only thing that isn't jdm are my racing seats there from bomz
badboy4life
Sep 1, 2007 08:28 AM
addiction2bass
Mar 26, 2007 08:49 PM
BottleBoy90
Mar 24, 2006 09:04 AM
CallawayCrazy3
EK Swaps
Feb 27, 2006 06:24 PM
glada96EX
EK Swaps
Feb 27, 2006 12:59 PM
