A/C Intermittent Cooling
Old May 30, 2010 | 10:51 AM
tradosaurus's Avatar
Default A/C Intermittent Cooling
Summer is here.
Problem is that the A/C cools when car is first used for the first 30 minutes or so and then stops cooling.
I put in a can of refrigerant the other day and drove the car 25 miles during the heat of the day to run some errands. A/C worked great. Then on the way home A/C wasn't cooling very well.
I hooked up a A/C manifold gauge this morning and here is what I found:
Static pressure at 90 F ambient temperature:
Low side = 85 psig
High side = 90 psig
Load pressure at 1,500 rpm
Low side = 22 psig
High side = 230 psig
From pressure temperature tables it appears that the system is OK but does anyone see issues with these readings?
Old May 30, 2010 | 01:50 PM
What year Civic?
When the A/C won't cool well, dose the condenser fan fail to run or does the compressor clutch fail to engage, or both?
Old May 30, 2010 | 06:43 PM
Originally Posted by RonJ
What year Civic?
99 Civic EX.
I will have to pay attention next time and give you a definitive answer.
Rabbit
Aug 9, 2014 03:28 PM
Hi Octane
May 27, 2013 05:39 AM
Expando1
Aug 12, 2005 08:34 PM
importmech
Oct 14, 2004 09:25 PM
Expando1
Sep 20, 2004 11:41 AM
