turbo will not make anymore boost
Old Jun 10, 2010 | 12:31 PM
greenbeen4's Avatar
Default turbo will not make anymore boost
it seems like the car wont make any more boost up to 10lbs, i turned up the boost with the boost controler and it still stays at 10lbs. i tightened all the turbo plumbing thought it might be a boost leak and its still acting the same way. it use to be around 15lbs and when i turned it up to 20 the car would shut down form not enough fuel, and when i turn it all the way up now, it will shut down on me like it would if i was running 20lbs but my boost is still reading 10lbs.please help with any other ideas on what it could be
Old Jun 11, 2010 | 04:29 AM
We'll need full details on the setup you are running before we can be of any real help.
It definitely sounds to me like a boost leak, just hard to say where. I would check around the BOV area, as well as the BOV it'self in addition to checking pipes and vac lines
ChillyPhil
Nov 7, 2008 04:49 PM
StifflersMom
Jul 8, 2006 11:22 PM
usmc2b2004
Feb 27, 2006 12:06 AM
str8racn
Nov 10, 2005 11:53 AM
StifflersMom
21
Nov 10, 2005 09:25 AM
