need more boost
Old Aug 5, 2004 | 09:32 AM
Lab Rat 21's Avatar
Default need more boost
now that i have gotten over my coolant problem, i have been able to really push the car. but because my turbo is so big (T3/T4-.60 ar) and high altitude (6500 feet) i only make about 3.5 pounds at 4500 rpm. i would like about 7 pounds at 3500 rpm. i'm thinking of getting smaller turbo housing, maybe T3, and a manual boost controller. what else can i do?
Old Aug 5, 2004 | 11:56 AM
2000Si's Avatar
Default RE: need more boost
Get a new wastegate and your manual boost controller.
Old Jan 6, 2006 | 11:30 AM
boosted_honda's Avatar
what fuel are you running. meaning is it the stock fuel system or injectors,fuel controller,ecu tunning or none of the above? 2000SI is right get the wastegate and boost controller and if you want it to spool faster get a smaller turbo. you may not be making enough exhaust gas pressure to spool the big turbo.
Old Jan 6, 2006 | 12:27 PM
Marty's Avatar
what size is all your piping, smaller charge piping in conjunction with larger downpipe and exhaust will get you to spool earlier.
Hola
Jul 23, 2008 04:06 PM
tilstad
Apr 1, 2006 02:37 PM
usmc2b2004
Feb 27, 2006 12:06 AM
Lab Rat 21
Jan 7, 2006 02:06 AM
str8racn
Nov 10, 2005 11:53 AM
