rusted bolts on struts
Old Aug 10, 2005 | 04:40 PM
ballplaya4eva07's Avatar
Default rusted bolts on struts
i went to install my new front strut bar today and the strut bolts are very rusted. I tried to loosen them and they started to chip away. Could i find new bolts at a hardware store? And how can i remove the rusted bolts?
Old Aug 15, 2005 | 02:33 PM
SugaDaddy's Avatar
Default RE: rusted bolts on struts
You can find the bolts, they are no problem, try putting WD40 on first and waiting for couple of minutes, if the sides on the bolts are worned, which means rounded, you are either going to have to use the locking pliers to take them off.
Old Aug 15, 2005 | 03:08 PM
Mossy's Avatar
find a large wrench to fit the nut (wrench, not ratchet). after spraying with wd-40 or another rust remover, tap the wrench with a mallet and it should knock loose
Old Aug 15, 2005 | 10:47 PM
mxs's Avatar
mxs
I just got some stuck bolts out with penetrating oil and a hair dryer, along with some patience and brute force... it worked pretty well
Old Aug 15, 2005 | 11:21 PM
XCM828's Avatar
For rounded bolts, these work like a charm:
http://www.sears.com/sr/javasr/produ...+Taps+%26+Dies
Old Aug 16, 2005 | 01:38 AM
thanks for the help. i used some wd40 to help loosen the bolts and the strut bars are great.
Old Aug 19, 2005 | 09:03 PM
green98lxsedan's Avatar
pb breaker workd wonders
Old Aug 19, 2005 | 09:05 PM
fixntune's Avatar
When all else fails....Hit it until it gives
bobertv123
May 24, 2012 10:02 AM
inthezoneac
14
Oct 15, 2008 07:08 PM
TheInternet
Jan 12, 2008 07:17 AM
:94CIV:DX:
Jul 21, 2006 12:35 PM
dfdon
Jul 3, 2006 01:18 AM
