TYPE R PISTON IN TO B18A BLOCK?
Old Aug 13, 2004 | 06:35 AM
JDMB16CIVIC's Avatar
Default TYPE R PISTON IN TO B18A BLOCK?
WILL INTEGRA TYPE R PISTONS FIT DIRRECTLY INTO A B18A (90' TEG BLOCK)?
Old Aug 13, 2004 | 10:51 AM
2000Si's Avatar
Default RE: TYPE R PISTON IN TO B18A BLOCK?
The A1 and C5 blocks have the same bore (81 mm) so I don't know why it wouldn't. You'd get some mad compression though.
Old Aug 13, 2004 | 11:02 AM
as far as i know, they will fit, but, check into the compression. also, dont do this if you are planning on using the ls head, i assume this is for the ls vtec project youve been asking about, if so then go for it, but the valve pockets in the type r pistons are located wrong for a non-vtec head and they will hit the valves. if you are using the vtec head, then it should be okay.
Old Aug 13, 2004 | 08:43 PM
2000Si's Avatar
I know compression will be bumped up. but to what, I don't know.
the ITR c5s stroke is 87.2 mm and the A1 block has a stroke of 89 mm. There's a calculator out there somewhere but it's inaccurate at best.
SMooTHn
May 16, 2006 12:17 AM
SMooTHn
May 14, 2006 12:45 PM
JDMB16CIVIC
Nov 30, 2005 08:51 AM
JDMB16CIVIC
Aug 11, 2004 07:29 PM
JDMB16CIVIC
