turbo dx
Old Aug 12, 2008 | 07:16 PM
nwcivic's Avatar
and another thing my brother is a chrysler mechanic and he thinks as soon as i put any boost on my motor its goin to blow up but i read around and most of the time it said that the crank is good but the rods and pistons will go at 200hp
Old Aug 12, 2008 | 07:39 PM
GReddy_Civic's Avatar
Snail'n Admin
it is NOT just horsepower that will kill your engine, torque does, as well as oil problems. You need quality parts, a good tune, and idea of what you are doing and TONS of research
Old Aug 12, 2008 | 07:41 PM
Snail'n Admin
Not true, there are TONS of civics running 200+ on stock internals (look at my sig). Chances are, your clutch will go or not be able to hold the power first. Make sure to run a compression test before you even go farther into consideration
Old Aug 16, 2008 | 03:02 PM
It's all about how much work you're putting on the engine, not the PSI. HP and TQ are what matters, not the PSI. A diesel truck turbo at 3 PSI would hardly spool at all, but once it did it'd put out more power than some DSM at 7 PSI. Go to the F/I section here on HCF and research until you can't anymore. Read every project thread, read Maximum Boost by Corky Bell, and then starting piecing a kit together for what you want. More boost/power means more new parts (even bigger injectors, clutch, stabalizer bars, re-tune every time you up the boost, etc) so figure out how much power you want and what parts you need, but before anything get a compression test to see if you can even handle it in the first place.
soldout712
Oct 30, 2006 11:05 PM
eg9
May 22, 2006 04:43 PM
forrealb50
Mar 29, 2006 07:57 AM
TrailorParkPimp
Aug 28, 2004 12:21 PM
