engine swap question
Old Oct 26, 2008 | 11:32 AM
D-Vegas's Avatar
Default engine swap question
i have a 98 civic ex with a b series engine from jdm(maybe b16...) swapped in(i bought the car from someone who already had the engine put in). when i took the car to have it inspected the obd would not connect or communicate with the shops computers(they tried two different computers). there are no check engine lights on and no other issues with the car. any suggestions on where to start? the guys at the shop said maybe a fuse, but my cigarette adapter works fine. thanks.
Old Oct 26, 2008 | 12:29 PM
Check whether fuse 43 under the hood is blown (see diagram). When the key is turned to ON (II), does the CEL turn ON for 2 seconds and then turn OFF?
Old Oct 26, 2008 | 01:08 PM
bigolsackapoo's Avatar
If you want to know what engine you have then look on the left side of the engine right next to the transmission. Here.....Do you see the stamp that sais b16a, look for that.
Old Oct 26, 2008 | 01:15 PM
Nice photo, sackapoo.
Old Oct 26, 2008 | 01:24 PM
Thanks dude.
Its always a good idea to know what engine you have.
Old Oct 26, 2008 | 01:35 PM
D-Vegas's Avatar
thanks for the quick responsesand i agree... the pic and the diagram are both most excellent. the engine is a b16a and fuse 43 is not blown. and yes, when i turn the key over the CEL comes on for 2 secs and then goes off. any more ideas would be greatly appreciated. i am quite the novice at civic tuning. thanks again.
Old Oct 26, 2008 | 01:39 PM
is it using the JDM ecu? that might cause a problem for them, not sure
Old Oct 26, 2008 | 01:42 PM
D-Vegas's Avatar
i do not know if its using the jdm ecu. the engine had already been swapped when i bought the car.
Old Oct 26, 2008 | 01:47 PM
Remove the passenger kick panel and post some photographs of your ECU. As Trust mentions, a jdm ECU may have problems communicating with OBDII scan tools.
Old Oct 26, 2008 | 01:48 PM
hmmm
well if you do that is the problem
"no jdm ecu will pass usa inspection or smog"
quoted from:
http://www.honda-tech.com/zerothread?id=2295128
