How do I check if the ICM is working?
Old Oct 28, 2008 | 06:55 PM
crazyflippindude's Avatar
Default How do I check if the ICM is working?
My car ran perfect till yesterday it died while i was driving it and now won't start, cranks but won't fire. Can hear the fuel pump, and smell gas when i crank it. Theres no spark. brought the coil to autozone and it checked out. The rotor worked properly when i cranked it also and the points seemed fine on the cap. How could i tell if i needed a new cap and rotor? there wasn't any corrosion inside the distributor. My next thing to get checked is the ICM. How can i go about getting it checked to see if it works properly?thnx
Old Oct 28, 2008 | 07:03 PM
The service manual does not mention a direct test for ICM function, but I believe that AutoZone will test your ICM free of charge. Remove it from the distributor and bring it to the store.
-Have you checked whether the distributor connector has battery voltage when the key is turned to ON(II)?
-Is the CEL ON?
-Have you checked whether the timing belt snapped?
Old Oct 29, 2008 | 08:09 AM
I asked Autozone and they don't have the equipment to check it ICM. I checked and there is voltage coming from the distributor. When i turn the key to the (II) position the CEL goes on for a second or two and then goes off. The timing belt and water pump have been replaced within a year so i doubt it snapped. The ICM is connected by 2 screws i believe, one i can get at and the other one i'd have to take out the camshaft i think? I'm sorta afraid to take the distributor more apart, potenially screwing up the timing or something and making more problems? I'm lost on what to do now...
Old Oct 29, 2008 | 09:28 AM
Call additional auto parts store about bench testing your ICM. Do you have a 96-00 Civic?
You can determine whether the timing belt snapped by removing the oil fill cap and looking under the valve cover with a flashlight to see whether the cam turns while a buddy cranks the engine.
To access the ICM, you need to remove the rotor. The diagrams may help:
trustdestruction
Jul 2, 2009 09:11 PM
drumforever
15
Jun 8, 2009 03:50 PM
GAMBOA
14
Nov 23, 2007 01:59 PM
honda_farmboy
20
Aug 7, 2007 05:29 PM
billthepill
Jul 14, 2005 01:49 PM
