preventive matiance for tranny's
Old Nov 8, 2008 | 09:32 AM
firecatf7333's Avatar
Default preventive matiance for tranny's
i own a 98 civic dx 5 spd stick, with 75k, and am just looking to do a regular tune up b/c idk what the previous owner has ever done, and don't want long term headaches b/c i plan on keeping the care a while. Any suggestions or tips on how to keep the tranny going smooth and well for a long time. I was told to change tranny fluid, but there is no filter on the civic. Anything else, thanks
Old Nov 8, 2008 | 04:13 PM
Change the tranny fluid (drain and refill).
You need 2 quarts of manual transmission fluid. Don't cheap out - use only Honda genuine Manual Transmission Fluid. It's about 6.50 a qt at your local Honda dealer, and you will need 2 bottles.
here's the DIY instructions: http://www.honda-tech.com/zerothread/1687986
That should be all the maintenance your transmission will need.
Old Nov 12, 2008 | 12:49 AM
Koopa Troopa's Avatar
I run Castrol GTX 15w-50 motor oil in my transmission.. '98 ITR mission with Mugen diff... No need to spend 6.50 a quart.
Old Nov 12, 2008 | 10:28 AM
V8DIET's Avatar
I'd def go with the Honda stuff. Better safe than sore. :-)
Old Nov 12, 2008 | 11:44 AM
I used to run Mobil1 synthetic motor oil in my transmission, but it was grinding a little shifting into gears too hard. I changed it and put in genuine Honda manual transmission fluid and the grinding stopped.
Seriously? You only need two bottles, which is $13. Why would you cheap out and get anything other than Honda manual transmission fluid when it's only $13?
Old Nov 12, 2008 | 11:47 AM
baker's Avatar
honda fluids are the proper fliuds for your vehicle. use them and your car will appreciate it.
firecatf7333
Nov 9, 2008 04:59 AM
87DX2D
Sep 29, 2008 10:28 AM
davster
Sep 28, 2007 10:23 AM
pregohatch
Jul 9, 2006 09:21 AM
darknightmr2
Mar 14, 2006 06:44 PM
