2000 Honda Civic Radio - HELP!!!
Old Oct 7, 2008 | 11:30 AM
iamsomewhere's Avatar
Default 2000 Honda Civic Radio - HELP!!!
I just recently purchased a 2000 honda civic w/the factory radio installed. I followed the instructions of the "installdoc" PDF's that I got off this forum to do an aftermarket install (Pioneer DEH-P400ub iPod deck) and have run into a wall.
Last night I went to plug the deck in and when I turned on the ignition... nothing. At first I thought I may have wired the harness wrong, or the new deck I had purchased was bad. To veryify if this was the case or not I figured I'd just plug the factory deck back in, so when I did... NOTHING!
Now nothing works! Neither the factory or aftermarket decks work! What did I do wrong? I've checked the pins on the wiring harness of the civic w/a multi-meter and it's putting out 12V. The only remaining thing I can think of is this: Does everything else (A/C controlls, cigarette lighter, power mirror controls) have to be hooked up as well in order for the deck to work? I haven't done that yet because I'm afraid I'll get it all back together and it still won't work. That would be a pain in the @$$.
If anyone has experience or could point me in the right direction I'd really appreciate it!
Old Oct 7, 2008 | 11:58 AM
A broken or disconnected ground wire is a possible explanation. Check whether the black ground wire has continuity.
Old Oct 7, 2008 | 12:03 PM
when I used the multimeter I put the negative (black) probe into the pin (black wire) on the harness. Would that rule out the possibility of the ground wire issue?
Old Oct 7, 2008 | 12:11 PM
I am not sure I understand what you did. You need to use your multimeter to verify that the black wire has continuity with ground, such as the metal frame under the dash.
Old Oct 7, 2008 | 12:21 PM
yeah... that's what I meant. When I used the multimeter I checked both the frame (had continuity) and the black wire (had continutiy) via the radio harness plug.
Old Oct 7, 2008 | 12:23 PM
any other thoughts? What about the dash re-assembly idea I was talking about in the original post? Does it matter if everything else is hooked up or not? Or should the radio just work regardless?
Old Oct 7, 2008 | 12:58 PM
No, the radio should work independently of other components. This is verified by your ability to detect 12V from the hot wire and continuity from the ground wire.
Old Oct 7, 2008 | 01:12 PM
Did the 2000 civics have a radio anti-theft device? I've heard that there is a code that has to be re-entered if you change your battery or something along those lines. Could this have anything to do with it?
I'm just trying to figure out ANY possible reason... *head scratch*
Old Oct 7, 2008 | 01:45 PM
Sigracer10's Avatar
might be repeating something, but did you check that both the +12V constant and the switched ignition (yellow and red wires) show 12 volts with the ignition on.
and did you check all your fuses including the one on the back of the actual radio
Old Oct 7, 2008 | 02:00 PM
I'll double check everything after work tonight and report my findings.
I really appreciate everyone's help... thanks a ton!
