JDM B16A2 - same ignition timing as a USDM B16A2 ?
Old Oct 2, 2008 | 01:55 PM
Captain_Sl0w's Avatar
Default JDM B16A2 - same ignition timing as a USDM B16A2 ?
Hi,
Is the ignition timing for a JDM B16A2 the same as its international, or say American counterpart. I know the fuel octane is different, but how might this affect the ignition timing. Basically is the ignition timing for a JDM B16 retarded or advanced when compared to a USDM B16?
secondly if anyone knows, Ive also put ITR cams in my B16A, would i need to change my ignition timing in light of this? Whats everyone's experience with stage 1/ITR/CTR cams?
Old Oct 3, 2008 | 10:14 AM
bcivic's Avatar
The mechanical timing or the ecu timing ? Stage 1? CTR cams are stock cams from civic type Rs or the b16b stock cam. And to get the most out of the cam it should be tuned at the very least you should get the timing light on it after you swap the cams. Also are you changing redline ctr make more power up top to 8900rpm ?
Old Oct 4, 2008 | 03:05 AM
i meant the actual ignition timing, mechanical timing if you will, the kind you use a timing light and rotate the distributor to set.
ic892003
Oct 23, 2007 09:53 PM
ic892003
Apr 5, 2007 11:04 PM
ej6buddy
EK Swaps
Jan 26, 2007 12:24 AM
BallardCivic
Dec 8, 2005 04:05 PM
Street Sniper
Jun 7, 2005 08:37 AM
