Leak down test results should i be WORRIED
Old Dec 1, 2008 | 05:45 AM
tombakers's Avatar
Default Leak down test results should i be WORRIED
hi, had my built b16 turbo engine leak down tested today and was worried alittle by the results,
Cylinder 1: 12 %
Cylinder 2: 6%
Cylinder 3: 8%
Cylinder 4: 9%
(comp test is fine though)
now i have heard anythin up to 10 % is ok but anythin above and there is a problem.. they reported it wasnt valves but ring leakage......
engine is running 9:1 pistons blockgueard and was built dec last year.. block was rebored and deckes upon build
i have further tune comin up to really get the car up to speed and sorted, should i be worried about this leakage?
Thanks
Old Dec 1, 2008 | 11:22 AM
riceburner700's Avatar
if the compression checked out good and those aren't bad numbers, if you had like %20 leakage i would start to get worried. i would say watch the %12, if it starts getting past %15 i would start looking into it
jamned
Nov 30, 2007 06:48 AM
uranium238
Sep 22, 2007 10:57 PM
the_turtle
Jan 17, 2007 09:19 PM
meangreen
Feb 28, 2006 01:59 PM
imagerockone
Jan 9, 2006 09:35 PM
