Should i be worried?
Old Jan 17, 2007 | 12:38 PM
the_turtle's Avatar
Default Should i be worried?
my header is cracked from about 3cm. above the o2 sensor, and its not all the way through....should i be worried about it breaking? if it does crak all the way through, what is the wors that could happen, just a bad leak? also, im really not worried about buying a new one, if that time comes, then, ill just buy one. no biggie.
Old Jan 17, 2007 | 03:17 PM
blackmetal619's Avatar
Default RE: Should i be worried?
just use some sort of epoxy or something that will hold it together a little longer before it has to be replaced...how did it get cracked?
Old Jan 17, 2007 | 09:19 PM
Stumasters's Avatar
Headers aren't that pricey, but if you have one like I do with the built-in Cat converter, that would suck.
I would say fill the crack with some heat resistant stuff and make due till you can afford a new one.
babyivan
Jun 23, 2008 11:55 AM
bdouglas
Mar 12, 2008 11:13 PM
uranium238
Sep 22, 2007 10:57 PM
meangreen
Feb 28, 2006 01:59 PM
imagerockone
Jan 9, 2006 09:35 PM
