A few questions about pistons
Old Mar 14, 2007 | 07:25 AM
  #21
Default RE: A few questions about pistons
redlines usualy affected by transmission (i believe)
and maybe he was talking about getting an upgraded valvetrain kit?
Old Mar 14, 2007 | 07:27 AM
  #22
Mr Mobsta Man's Avatar
No, I'm pretty surehe was strictly asking if that if you change your pistons will your redline be effected. Flip, for the transmission. It would effect what speed you are going when you reach your redline, notwhat rpmyour redline is.
Old Mar 14, 2007 | 07:37 AM
  #23
oh no sh*t, my bad i even knew that.....yeah Mobsta has it right BCivic, your redline will be at the same RPMs, but you will be going alot faster when you reach those RPMs
Old Mar 14, 2007 | 09:51 AM
  #24
StifflersMom's Avatar
Cat Fuсker
Flip...either talk clearly or stop talking out of your ***. The only way he'll go faster at the same RPM is if the gear ratio is somehow changed.
Old Mar 14, 2007 | 10:06 AM
  #25
doesnt that have something to do with the transmission?
Old Mar 14, 2007 | 10:38 AM
  #26
Cat Fuсker
Like I said, write in complete damn sentences with a point to your postor what you're saying makes no sense and confuses me and pisses me off in the morning. And yes, changing the gear ratios in done by messing with your tranny.
Old Mar 14, 2007 | 12:34 PM
  #27
BCivic93's Avatar
So will changing the pistons make my car faster? it's a d16z6
Old Mar 14, 2007 | 12:55 PM
  #28
Cat Fuсker
If you get higher compression pistons you should gain some power, but the tradeoff will be the need for higher octane fuel.
Old Mar 14, 2007 | 01:40 PM
  #29
BCivic93's Avatar
Is it like whatStreetSniper wassaying on the prev page of this post, that approx every point of compression is about 8 to 10 hp? Like if i got 12:1 I'd gain about 21 to 26 hp since I'm at 9.4:1 now?
Old Mar 14, 2007 | 03:54 PM
  #30
Kedawei's Avatar
The rule of thumb is, that in general for every 1 point of compression added, a 3% increase in power is gained.
