A few questions about pistons
Old Mar 14, 2007 | 03:59 PM
  #31
Mr Mobsta Man's Avatar
Default RE: A few questions about pistons
So for the d16z6 that would be 3.75 hp for every one point compression...give or take I'm sure.
Flip, for speed at a set rpm thing. It doesn't matter if you have 90hp or 400hp, you will redline at the same speeds unless you change the gear ratios.
Old Mar 14, 2007 | 05:06 PM
  #32
HaZe89's Avatar
what kind of pistons does a d16z6 stock engine has??? is it low compression???
Old Mar 14, 2007 | 05:17 PM
  #33
ej6buddy's Avatar
wow, some of you guys need to get to reading,
in auto parts stores, they have hayne manuals to show you how internal combustion engines operate, and other mechanical and electrical systems work, i've never used one, but it might be pretty helpful to someone that knows nothing of cars before they screw something up.
and i don't think you need to see that mechanic either, and don't let him touch your motor, and i don't suggest you touching it either with your knowledge.
DjHagios
Jan 20, 2012 03:46 PM
oldguy
Mar 17, 2007 01:03 PM
mitch_cox_kc
May 27, 2005 05:06 PM
Orin
Apr 1, 2005 11:36 AM
foozball
May 25, 2004 11:56 PM
