turbo suggestions
Old Mar 22, 2007 | 06:53 PM
  #21
BillyB98's Avatar
Default RE: turbo suggestions
I know no one said that but sov said it would be a waste. Does anyone have any piston suggestions or cam, valve, springs, retainers, etc suggestions? Would 450cc injectors be good for my goals w/ a Walbro 255lhp fuel pump? And how does a 25T or TD04H turbo sound?
Old Mar 22, 2007 | 07:43 PM
  #22
Kedawei's Avatar
It's not a waste if you do it right, ie build way cheap. Stock rods, OEM pistons of desired compression, walbro pump, dsm injectors, T25 or 14B turbo, CX/VX/STD manifold + adapter plate, Z6 head/IM (Z6 block preferably as well), zex cam, Z6 or equivalent ECU, DIY street tune via Crome. That's 200-250whp for 700-900 bucks. Cheap is the only way to go on Hondas imo.
Old Mar 23, 2007 | 12:44 PM
  #23
BillyB98's Avatar
Im actually starting to look for a cheaper z6 that i can just rebuild and turbo then swap that into my car.
Old Mar 23, 2007 | 01:49 PM
  #24
ORIGINAL: Kedawei
wow, that gives Pete's Grocery List a run for it's money
Old Mar 23, 2007 | 06:08 PM
  #25
BillyB98's Avatar
ok well as ive been asking many different people on here which direction i should go ive gotten many different responses. Some say mini me, some say build the y7, some say swap a whole new motor, etc. and since i really want a dependable daily driver ive decided to stick with my y7. I looked at riceburner700's y7 build and I think im going to try to follow that and build up my y7 and eventually swap to a 96-00 EX tranny. So im really open to suggestions on what to do to the engine and what products to go with. Kedawei why do you say go with stock rods and OEM pistons? jw
Old Mar 23, 2007 | 06:25 PM
  #26
SovXietday's Avatar
I didn't say it was a waste to turbo the Y7, I said building the Y7 and then making 220whp out of it was a waste. You can do it easily on stock block, even easier if you do a minime. You just need a good tune.
Old Mar 23, 2007 | 06:44 PM
  #27
Kedawei's Avatar
ORIGINAL: SovXietday
Ah, my fault. That makes sense.
Old Mar 23, 2007 | 06:53 PM
  #28
Kedawei's Avatar
ORIGINAL: 98 CivicDx
Just fyi, I now know of 5 Y-series engines that have burnt up bearings in their bottom end, and I'm sure I'd know of more if I had been in the Honda scene long enough and/or deeply enough. That is why I said "Z6 block preferably as well." The Y series might work fine with oil flow modifications, but I couldn't say. It might not be worth the risk. Riceburner is just using a Y7 head on a D15 bottom end I believe. I dunno I'm too lazy to check.
As for the OEM rods/pistons, for such low goals that's just what I'd do. If you're really worried about it use Eagle rods/OEM pistons. The rods are the weaker of the two.
Old Mar 23, 2007 | 08:19 PM
  #29
BillyB98's Avatar
OK well this is going to be a hell of a project so im gonna really begin searching for a z6 engine then redo that. Would you think that would be better to turbo? If i rebuilt that with the eagle rods, oem pistons, and either a zex cam and new oem valve springs etc. or the akmee kit what would i be looking at making with a pieced together turbo kit, around 250?
Old Mar 23, 2007 | 11:15 PM
  #30
Kedawei's Avatar
Z6 would be best.
You'd probably make around 200-220 with a T25, and 250-280 with a 14B. T25 will spool much quicker. Just depends what you want from it. There are other turbo options, but none as cheap as these that I know of.
