Royal Purple
Old Jun 13, 2007 | 02:22 PM
  #31
Bigwill93hb's Avatar
Default RE: Royal Purple
i was joking around cuz all these name brand oils are being said so i thought i would say something! but i use mobile 1
Old Jun 13, 2007 | 03:51 PM
  #32
ej6buddy's Avatar
ORIGINAL: mlobitz
ORIGINAL: ej6buddy
ORIGINAL: Aslan817
definitely a noob question...can I just switch to synthetic whenever i get my oil changed which is in the next couple weeks? Also any suggestions for octane boosters, my dad gave me some of his 0-60 idk if I'm supposed to notice any difference and would it do anything if I'm putting supreme in my car already?
it's not good to switch from conventional to synthetic just all of a sudden, just keep it with conventional. and about the octane booster, just throw it away, it's not good for the fuel system.
Why do you feel it's not good to switch from dyno to syn? As long as your car has been maintained, it won't matter at all. Most people see issues when the syn oil cleans the old sludge and **** out, but it shouldn't matter if you have taken care of your vehicle. There are lots of people out there who say it causes leaks, but these statements are un-merited. The leaks were already there, but the syn oil cleans up all of the gunk that filled in the leaky areas. Switching to syn would be no different than running a dyno oil with a cleaner agent in it or running seafoam in your crankcase.
switching to synthetic doesn't "clean the old sludge and **** out" as you may think. switching half way through a motors life will promote leaks in the seals because the "synthetic" additives that they use to again "clean the old sludge and **** out" causes the seals to deteriorate and therefore cause leaks. and about the bold statement, where is your evidence to back that up since you're so educated in this manor. i for one have seen this happen many times, and it has been tested as well. it will not harm you're engine as much as you think, but it is recommended to stick with conventional oils when you've been using them. a half/half mix is fine as well.
Old Jun 13, 2007 | 04:01 PM
  #33
ic892003's Avatar
well i didnt do the half and half mix, i jus ran 4quarts of royal purple after using nonsyn oil, wut should i do for my next oil change ?
Old Jun 13, 2007 | 04:14 PM
  #34
ej6buddy's Avatar
ORIGINAL: ic892003
oil is oil, just use whatever you want, that's why they have so many choices and brands for you to choose from, just pick the correct weight (depending on time of year)
Old Jun 13, 2007 | 04:19 PM
  #35
ic892003's Avatar
whats the correct weight for this time of year, how bout for winter?
Old Jun 13, 2007 | 04:23 PM
  #36
ej6buddy's Avatar
that's just a matter of opinion, you can run 10w30 or 5w30, both get the job done all year long. the weight determines the viscosity and the temperature it needs to reach before it's optimal performance. do you get very cold winters?
Old Jun 13, 2007 | 04:28 PM
  #37
ic892003's Avatar
dont know what would be concidered very cold lol, but i live in nyc so it isnt extremely bad, but yes it gets cold
Old Jun 13, 2007 | 04:32 PM
  #38
ej6buddy's Avatar
if it's very cold, you can run some 10w40, if it's normal, you can just run normal 10w30. the colder the weather is, the thicker the oil is, so you would want a thinner oil to compensate. but in the end, it's just a matter of preference.
Old Jun 13, 2007 | 05:00 PM
  #39
ic892003's Avatar
k thats good to know, thanks for the short lesson on oil
H22
Oct 27, 2006 02:52 PM
rikstaker
May 30, 2006 12:56 PM
92B18A1Hatch
Apr 28, 2006 02:32 AM
Amanda
Apr 13, 2006 05:09 AM
