Sanding plastic
Old May 9, 2008 | 06:08 PM
croninc's Avatar
Default Sanding plastic
How should i go about this, wont it just scratch the crap out of my bumpers??? Lemmie know and if anyone has done this lemmie know ty!
Old May 9, 2008 | 06:21 PM
croninc's Avatar
Default RE: Sanding plastic
hump de bump
Old May 9, 2008 | 09:01 PM
cyberx32's Avatar
Yeah it will make the plastic all nasty, you are gonna need bondo to make it smooth
Old May 12, 2008 | 11:58 AM
chunkbird's Avatar
That's good to know, I sanded by bumper a bit too much in spots... and I was hoping the primer (it says it is a scrape filling kind)would fill it , but bondo is a great idea!
Old May 12, 2008 | 06:43 PM
baron340's Avatar
you may need some glazing putty but dont get crazy with bondo. it should sand easily. i repainted my bumper and the plastic sanded just fine, you just have to use a little higher grit so you dont eat it away and scratch it up though. but if you are just repainting it you shouldnt have to sand it back down to the plastic.
Old May 12, 2008 | 07:52 PM
ej6buddy's Avatar
well, if it's a deep scratch, then you'll need to puddy it in, and sand with about a 1500, 1800, or 2000 grit sandpaper as the final. and try to keep the wiping pattern in the same direction and curve around the bends. and if it's black trim, then go to your local store and buy some oem black trim molding paint and spray a few coats, then it'll look like new.
Johnny Appleseed
May 10, 2010 06:46 PM
civic guy
Oct 13, 2008 11:13 PM
HuGGyBear305
Jun 2, 2008 05:48 PM
asadzanjani
Mar 9, 2008 01:29 PM
justinprime
Mar 30, 2006 11:40 AM
