Audio/Video & Electronics DIYs For all you sound/video junkies
DIY - Main Relay Repair
Old Jun 28, 2011 | 11:26 PM
jbum's Avatar
Default DIY - Main Relay Repair
I've been meaning to tackle that annoying main relay issue that I've known about for the longest time. Finally got around to it and thought others might appreciate a DIY on it While it's not a difficult task, it's always nice visually seeing how others have done it. It always helps me.
You'll need the following items for the job:
- Screwdriver (philips)
- Flat-head screwdriver
- 10mm box-head wrench
1. Disconnect the negative terminal on the battery. I didn't do this step and it has been fine but I think it's better to do this.
2. Remove the fuse panel and lower driver-side dash panel. Use the philips screwdriver for this.
(No picture - sorry but it should be obvious)
3. You should be looking at something similar to this
4. Look right behind the hood release. There is a grey plastic box. That's the main relay.
5. The main relay is held by a bracket which is held on by a 10mm bolt. Use your box-head wrench to take this off. Be very careful. I had the bolt fall "somewhere" and I lost it. Good thing it's not a crucial part but still sucks.
6. Unclip the wire harness that is attached. I used a flat-head to pry it off. It's pretty stuck on and hard to do it by hand.
7. There it is!
8. Getting the main relay cover off is a bit tricky. You have to pry the ends out enough for the board to come out.
8. You can see that the solder has cracked around the metal post here. The same crack exists on the opposite end.
9. My soldering job isn't the prettiest but it did the job.
If you've never soldered before, this youtube video is really good.
10. Now put the main relay back and follow the steps in reverse. Hope that fixes your intermittent issues with the engine starting!
Last edited by WellFedHobo; Nov 4, 2019 at 03:34 PM. Reason: Updated images to locally hosted ones instead of photobucket ones
Old Jun 29, 2011 | 04:55 AM
Nice writeup. Moved to the electronic DIY section.
ktorres1120
Sep 4, 2013 08:07 PM
rzimmer11
Aug 18, 2005 11:45 PM
ICONOMAT
Dec 13, 2004 10:44 PM
96EX_NC
Aug 18, 2004 09:40 AM
sweetzcivic
Jun 17, 2004 11:47 AM
