Amp Grounding
Old Nov 17, 2006 | 04:20 AM
NorCalRice's Avatar
Default Amp Grounding
So, I just got a cheap used 300W amp and sub (thanks craig'slist!!) and I hooked everything up - 8 gauge power/ground wire, firewall successfully breached and resealed, power/remote wires down the passenger side, RCA's down the driver side. I have the amp and sub in my trunk, and I was wondering where the best place to ground the amp would be?? I realize I need a clean piece of metal for the connection, and I am not opposed to any sort of sanding of paint, but I'd like to use a bolt that is already there if possible.
Old Nov 17, 2006 | 06:18 AM
matts's Avatar
Default RE: Amp Grounding
why are you opposed to sanding so much? rust? if so, after you sand it down and screw your ground down take a little grease and smear around it...or clear paint.
if you still dont want to just find a bolt/screw within about 3ft. of the amp and bolt it down
Old Nov 17, 2006 | 09:53 AM
mill$civic's Avatar
Big T
Mar 7, 2006 10:08 PM
jad1217
Dec 11, 2005 11:09 PM
nightrider46
Dec 3, 2005 05:02 PM
Clean98EX
Sep 17, 2005 08:33 PM
farsighter2000
Aug 28, 2005 01:40 AM
