amp to speakers
Old Sep 28, 2006 | 03:13 PM
dfdon's Avatar
Default amp to speakers
will this help distortion
Old Sep 28, 2006 | 03:20 PM
mxs's Avatar
mxs
Default RE: amp to speakers
please explain?
Old Sep 28, 2006 | 03:37 PM
dfdon's Avatar
if i power my front and rear speakers with an external emp will this help the distortion i am having
Old Sep 28, 2006 | 03:54 PM
mxs's Avatar
mxs
what is your current setup?
Old Sep 28, 2006 | 04:29 PM
dfdon's Avatar
pioneer deck, memphis audio front and rear, 2 x memhpis 12" subs, memphis amp powering woofers
Old Sep 28, 2006 | 04:55 PM
i would say it should if your speakers aftermarket.... get a 4channel amplifier with somemore power and rewire the speakers from amp to speakers!
im gonna do the same thing as soon as i get enough cash to buy a orion 4channel amp! my interior speakers SUCK bad at high volume!!!!!
only thing i think is the problem is that either thiers a external amplifier which with the aftermarket radio with more power is destroying the qualitly OR the speaker wires are so small they cannt handle the power.........
Old Sep 28, 2006 | 11:56 PM
sillyredcivic's Avatar
its not neccesary to "upgrade" your speaker wire from the amp to speakers. But a good four channel amp with adjustable crossover will help to dial oout distortion.
Old Sep 29, 2006 | 02:15 PM
id say it is... have you seen them tiny stock wires.LOL
i had a friend try to push 2 15s that was twice the big as my cheap @ss subs and my amp with half the power..... why i look at his setup and see some TINY typical household speaker wires.LOL i slaped on my fater wires and very nice bass...... told his @ss to go to walmart and buy some larger speaker wire! my speakers have a harsh sounds when you turn up the volume over 22, goes up to 33 and in my truck it sounded fine up to 30.... same components, same radio... different car and smaller wires!
the car was designed for that stock radio... so where probably only made large enough to handle that much power..... just not designed for changing the setup!
Old Sep 29, 2006 | 09:13 PM
mousetopher's Avatar
I would definitely run an amp and aftermarket speaker wire. You don't have to go crazy with it. But replace the speaker wire.
Old Sep 29, 2006 | 10:07 PM
dfdon's Avatar
yes smaller gauge wire has alot to do with your amps performance
Bostonhoodhop
Mar 10, 2007 06:26 PM
03civiclxcoupe
Jan 1, 2007 09:59 PM
Seth2367
Sep 29, 2006 07:02 AM
mombo
Sep 13, 2006 01:32 AM
00civiclx
Sep 30, 2004 04:48 PM
