Amps with speaker level inputs
Old Jan 21, 2007 | 06:26 PM
pWnEdU's Avatar
Default Amps with speaker level inputs
Amps with speaker level inputs suck in general, right? I don't want to get rid of the in dash 6 disk changer in our neon but I'd like to get some bump.
Old Jan 21, 2007 | 06:33 PM
Default RE: Amps with speaker level inputs
no not at all...
most amplifiers have that ability.... it just converts the speakers highlevel into a low level rca signal... preaty much the same as buying a high level adaptor to change your speaker wires into rca outputs....
main thing thats making them suck is your stock headunit not the amplifier!
Old Jan 21, 2007 | 08:02 PM
Stumasters's Avatar
I will agree. Most aftermarket head units put out a stronger signal through their RCA outputs, that helps your amp a ton. For example, my Alpine unit was one of the few I have seen that has a 4volt preamp output, most have a 2, some even a 1.
The stronger the signal, the better the sound in general.
They do however sell those converters, like addict said, that will convert your speaker level sound into a RCA output, and some even have signal strengtheners or what not, to help boost those factory outputs.
Here's a Link to a cheap one at crutchfield.
Here'sa Linkto one thats for single amp output, might be a little better overall construction.
Old Jan 21, 2007 | 08:06 PM
ya you can also pick those up at walmart
oddly enough my friends old system was louder with his crapy inline converter.LMFAO
cowsgonemadd3
Feb 20, 2008 06:30 PM
squirrellydw
Apr 9, 2007 08:58 AM
trifest
Feb 14, 2007 02:07 PM
Timcivic
Sep 8, 2006 07:00 AM
cowsgonemadd3
Jul 13, 2006 01:28 PM
