Better Bass Boom
Which setup do you guys feel would give louder deeper bass, two 10 jl w1v8 wired in paralell in a ported box presenting 4 ohms to a Kicker 350.2 bridged down to mono which would make it 350X1 divided into two speakers. Or three 10 jl w1v8 wired in paralell in a sealed box presenting 2.7 ohms to a kicker 600.1 mono block amp which I figure with the ohm load would make it about 400-500 watts. I know the 600.1 will run a lot cooler than the 350.2 because the 600.1 is a class D amp. I listen to alot of rap,r&b, dancehall and island music which carries crazy bass lines. Im trying different speaker setups and I wanted to see how the forum feels. Last question is it ok to hook up a 12" 4 ohm car audio sub to a home stereo system, I know home stereo's are traditionally 8 ohm.
how big are both of the boxes im talkin cubic feet and what is the ported box tuned to im leaning towards the 3 10's. the 12 on the home stereo is iffy it might play but it may go into protect when you turn it up what model stereo is it?
id say it would be pretty close. with the 2 ported or the 3 sealed... if you listen to mostly rap id think you would be happier with the ported setup. tho thats just IMO. no way to know for sure unless you get both installs and have both metered.
