powering amp?
sorry no experience on a 2005 BUT to make it less noticable just get some cheap black wire loom and simply cover the power wire and put some black electrical tape on the ends. that black loom will look close to stock and you should be able to hide it alot easier! for a few more finishing touches try to route the wire as much as posible around other stock wiring and use some black wire ties to keep the wire inplace. and try to simply find the closest wire loom around the battery and firewall.
its not to tuff to make it look like it belongs. just afew touches can make a big difference!
do what addiction2bass said and put the loom on the wire then make sure that you route the wire thru the firewall then under the carpet to get your hands under there you should be able to pop the door sills up and off then lift on the carpet just be careful not to break anything then just find the easiest way to get it into the trunk
