powering subs
Old Apr 14, 2006 | 06:27 PM
taintedsaint's Avatar
Default powering subs
i just got a couple alpine 10" type r's and i'm wondering if i need to put massive power into it or not. they're rated at 500rms with a maximum at 1500w . . . does that mean that i need a minimum of 500 watts going to each sub for it to sound good? also i was wondering if anyone knew where i could get an optima battery for cheaper than $150 and if you guys know of any good sound dampening material. this is what im looking at right now http://www.b-quiet.com/monte.html appreciate the help guys!
Old Apr 14, 2006 | 07:07 PM
Berzerker's Avatar
Default RE: powering subs
the RMS rating is the Constant usage rating.. meaning dont subject more than 500watts for extended periods... The 1500 watt rating is the amount they can handle for "burps" of bass for sound offs or very short blasts. Do not underpower those subs or you will wreck them. I would go with an amp that puts out at least 300watts rms per sub.
Berz out.
Old Apr 15, 2006 | 12:49 AM
bobbytonic's Avatar
ORIGINAL: Berzerker
Berz out.
In that case you'd better not ever turn down the stereo below maximum or you'll blow them...
On a serious note, it is impossible to blow a subwoofer by underpowering it. As long as you don't crank the gains to make up for the power that isn't there, you will be fine with no matter what power you give it, just might not sound good sub-300 watts.
Old Apr 15, 2006 | 03:53 AM
Berzerker's Avatar
By underpowering a sub I mean dont get a 150watt amp and crank the gain to the max. That is underpowering. Not having a 1000 watt with the gain all the way down.
Berz out.
Old Apr 15, 2006 | 01:07 PM
bobbytonic's Avatar
It doesnt really matter what amplifier you have, if it is a 1000 watt amp, the gain should be set to 1000 watts. The same goes for a 150 watt amp. The gain **** is not a volume ****. If you know what you are doing, the size of the amp does not matter.
Old Apr 16, 2006 | 01:37 PM
thx for the help guys. did you guys check out the dampening material? what do you think about that?
Rhino40
Jan 14, 2009 09:03 AM
95civic1.6l
Jan 4, 2008 11:03 AM
mill$civic
Mar 17, 2007 07:53 PM
FlipHKD720
Jul 25, 2006 07:51 PM
ptw711
Mar 9, 2006 03:27 PM
