The Big Three
Old Apr 23, 2007 | 08:55 PM
thi3v3z's Avatar
Default The Big Three
Hi im looking to upgrade the big three on a 00 EX, Batt - Gnd, Eng - Gnd , and Alt to Batt Posi. For people that have done this before im just wondering where the wires are. I know the batt- gnd, but as for the alt to the batt, i lose the wire from the alt behind the intake. Also where is the engine to chassis ground? more then one?[/align]
Old Apr 23, 2007 | 11:12 PM
the727kid's Avatar
Default RE: The Big Three
Make your own grounds. And your confusing your power wire for the starter wire, thats the one that goes into the intake. Find the alternator and follow it to the battery. As for the grounds it is block to chasis n chasis to battery. But the more grounds the better .
Old Apr 24, 2007 | 12:16 AM
thi3v3z's Avatar
well my alt wire doesnt run directly to my battery....
i only have 2 wires that run to my posi on my bat, 1 goes to starter, the other to my fuse block.
Old Apr 24, 2007 | 12:27 AM
thi3v3z's Avatar
My alt wire runs from my alt then wrapped in condoit with the main harness, then goes to my fuse block, then to my battery
Old Apr 24, 2007 | 01:23 AM
the727kid's Avatar
Well run one from where that wire is bolted on the alt directly to the battery, just put a fuse on it.
Old Apr 24, 2007 | 11:40 PM
97_ex's Avatar
why would you do this? what do you have to gain? just curious... never seen something like that!
Old Apr 25, 2007 | 10:10 AM
the727kid's Avatar
It is a very good addition to your electrical system. Doing this in 0 gauge wire allows MUCH more current to flow through the electrical system. Just think of it like this, stock wiring is usually 8 gauge. Imagine water going through a faucet. If you have the faucet half way open (8 gauge wire) water comes out but not a lot, but if you open it all the way (0 gauge wire) a lot of water comes out.
Old Apr 25, 2007 | 12:19 PM
97_ex's Avatar
how is this done??
Old Apr 25, 2007 | 12:26 PM
the_turtle's Avatar
replacing your wire with some big ol' 0 or 2 or even 4 guage wire.
Old Apr 25, 2007 | 02:01 PM
the727kid's Avatar
It is easy to do. GEt some 0 gauge wire and some rings, make one wire go from the bat + to the alt + and one from the frame to the block and one from the frame to the battery -.
