Building Custom Sub Enclosure
Old May 13, 2010 | 05:35 PM
Costa's Avatar
Default Building Custom Sub Enclosure
Okay, so I've picked up all the goods to set up the system in my trunk, now I need to build my enclosures.
My ideal setup would be with my sub built into a box in the spare tire area. I know I'm going to need to build up the floor to get the height I need but how much is the question.
According to Kicker (who made the sub) this sub needs at least 1 cubic foot of volume to work right. My question is, can that 1 cubic foot of volume be in ANY configuration? Specifically I mean - the sub has a mounting depth of 6 1/4 inches so could I make the internal depth of the box 7 inches and adjust the length and width to make the volume total at least 1 cubic foot? Or would I have to make it deeper?
Other then that issue, I think I can handle the rest. If I need to figure out another arrangement I can, but that spare tire area is dead space, thought the sub would look good there.
Thanks for the help...
Old May 14, 2010 | 07:59 AM
Superfly's Avatar
I'd give it a little more than 1" clearance, but no, it doesn't matter to much
Old May 14, 2010 | 04:27 PM
02Hatchback's Avatar
No it doesnt matter as long as it 1 cubic foot, but that is the very minimul (which means it isnt guna sound very good) My 12in rockford p2 is in a 13x20x26 and it sounds amazing. And the most important thing in a good system is the box, i would also recomend porting your box.
Old May 15, 2010 | 01:51 PM
Superfly's Avatar
Just cause it's the minimum cu ft doesn't mean it won't sound good. Granted, it will sound different than a bigger box, but maybe to him a smaller box sounds better. As for recommending a ported box, it depends on what the OPs goals are. Ported boxes take up more room, for one.
But you are right about the box being very important
Old May 15, 2010 | 02:33 PM
I think 02Hatchback is meaning like loud bass, not quality bass.
Old May 15, 2010 | 05:07 PM
excatly
Old Jul 1, 2010 | 06:03 PM
Tempe's Avatar
Ported enclosures most certainly can result in quality bass. Then again, Kicker is not known to be a SQ driver. If you're looking for more lowend and higher quality bass, just build a larger sealed enclosure closer to a 0.707 qtc
T
Old Jul 1, 2010 | 08:04 PM
excatly
quality bass > loud bass, ANY DAY
Old Jul 1, 2010 | 10:21 PM
supersize's Avatar
Sir Banned-a-lot
exactly, not to insult, but think about it, if the bass is so distorted that it blurs out the words and you hear your cone on the speaker, it dosent sound good. i got sony explodes, the cheapest subs around. i turn my bass all the way down on the head unit and turn off bass boost on the amp, i keep the treble up, and it hits hard and clear. now if i was to turn the bass up and bass boost on, it would hit harder but all distorted.. go for quality, youll realize later on why we say this
Old Jul 2, 2010 | 07:41 AM
d16soda's Avatar
1 cubic foot isnt enough to make any sub sound "good" unless your definition of good is ****. i work at a car audio shop and we build custom enclosures. the generic volume for a beatin' *** box is about 2 ft./cu to 2.4+. now it does matter if you are going sealed/vented.
lol and im going to just let you know right now, no matter what and how you put in the spare tire area, it will sound HORRIBLE. you are better off mounting 8"s on your deck if you want them hidden. just cant get good sound in that spare tire nook.
cvcrcr99
Oct 20, 2007 01:31 PM
customboxman
May 31, 2007 08:38 AM
Polygamy16
May 3, 2006 09:15 AM
PhatCivic01
Mar 6, 2006 12:34 AM
PhatCivic01
