Equalizers
Old Sep 18, 2006 | 07:04 PM
dfdon's Avatar
Default Equalizers
Hey guys i have a nice high quality headunit, 4 memphis speakers and 2 twelve inch memphis subs and i have some distortion when i crank it up will an equalizer help me out? thanks?
Old Sep 18, 2006 | 07:50 PM
windcalmer's Avatar
Default RE: Equalizers
First things first. Have you set the gain on the amps correctly?
Old Sep 18, 2006 | 08:16 PM
dfdon's Avatar
well i only have the amp on the subs and the shop did that
Old Sep 18, 2006 | 08:19 PM
windcalmer's Avatar
i would take it back the shop and have them check it out. if they did the work and it doesn't soud right, they need to fix it.
Old Sep 18, 2006 | 08:39 PM
dfdon's Avatar
it sounded good for a while they just put in the subs and amp since then i had put in the front and read speakers
Old Sep 19, 2006 | 01:00 AM
herbaleyes's Avatar
Have the shop check the gain, the filter selection, and of course, the built in crossover points. I bet it's one of those.
Old Sep 19, 2006 | 07:06 AM
dfdon's Avatar
cool thanks man
Old Sep 19, 2006 | 01:11 PM
BenDF's Avatar
Crossover points is one thing you should check.
Also, headunit power cannot compare to AMP power to drive your mids/tweets. You are going to get some distortion when you push the speakers towards the boundaries of what the deck can push. You can never have too much power. I had 300 watts RMS going to my mids/tweets, and it sounded GREAT.
I would go for a preamp over an EQ, but that's just me. I like the Audiocontrol preamps. Kicker makes a nice one as well.
Old Sep 19, 2006 | 05:20 PM
Remmy's Avatar
ORIGINAL: dfdon
That is a classic case of poor power distribution. Memphis ALWAYS makes inefficient, hungry speakers. Post the specs of them so I can take a looksy. Also, if you think about it, your head unit has an internal amp no bigger than your fist. You might want to look into a 4 channel for the speakers.
Old Sep 19, 2006 | 06:04 PM
dfdon's Avatar
