Help I cant get the console off my 98 civic
Old Mar 23, 2008 | 12:24 PM
Asster's Avatar
Default Help I cant get the console off my 98 civic
So I followed all the instructions found on installdr.com
and when I get to the process off actually removing the console out the bottom half of the console seems ready to slide out however the top half will not budge...
So I looked around the side through the glove box and it looks like the top half maybe screwed in...
does anyone have any experience removing the console from a 98 civic??
Old Mar 23, 2008 | 02:34 PM
civicduty96's Avatar
Default RE: Help I cant get the console off my 98 civic
did you take out the hazard button and defrost....theres screws hiding behind them
Old Mar 23, 2008 | 09:36 PM
Asster's Avatar
no man I didnt...thats what I figured but I have no idea how to get at those screws
if u have any ideas plz let me know thanks
Old Mar 24, 2008 | 09:03 PM
KarTuneMan's Avatar
After you pull down the glove box, after you drop the under dash on the drivers side, the entire panal under the radio comes out by removing the screws on the outside edges. A couple are hard to see, get down and LOOK. With a short screw driver, get the ones up by the cig. lighter. This panal will then pop off. NOW the next 2 screws are the pains. look under the radio, one is more towards the passenger side, the other is kind of in the middle. These screws don't need to come ALL the way out. but loosen them good. The radio will then slide out.
Old Mar 25, 2008 | 09:53 AM
Asster's Avatar
I removed 4 brass colored screwed from the metal bracket around the console but it wont slide out...the top half is still stuck i think the guy who said that theres screws behind the defrost and hazards might be on to something cuz this area seems screwed in (wont slide out)
Im ready to give up and take it to a professional cuz I want my new deck in now hahahah thanks tho guys
Old Mar 25, 2008 | 10:44 AM
most likely whats catching is the wire harness... on my 99 the harness was holding my radio console in. look under the dash behind the lighter plug location and look for a bunch of wires that are tied to the left brace. just use a knife and just cut the wire tie and you should have enough wire travel to pull the radio console out.
Vexorg
Feb 17, 2012 07:02 AM
kev2809
Aug 18, 2008 11:26 AM
addiction2bass
Interior DIYs
Aug 9, 2008 10:28 PM
red2000Si
Feb 11, 2007 01:06 PM
thebadgator87
Jan 11, 2007 09:52 PM
