Hood pin switch help!!
This seems simple enough, but obviously not for me.
I need to install a pin switch for my hood\alarm. You know, if someone opens my hood my alarm goes off. Can i tie into the factory door pins or something else? The switch/pin I have looks like the one below. A diagram for the actual wiring would help. Thanks for the help
if its on the same alarm system it should be wired together inside the brain. but if its dirty/rusty and not making a connection or just bent and sticking in the close position then it wouldnt work.
try to start the car and then pop the hood. if it cuts off then the switch is working fine. if it doesnt cut the motor off then maybe the wire poped off the bottom tip or the contacts are rusty/dirty and not making contact like it should!
those switches are commonly bent as well and if that plastic rod bends just slightly it will keep the contact points in the open position and unless the switch is all the way poped out it wont make contact.
i dont really like those switches myself. what i prefer now is tilt sensors, which are basically mercury switches.
muuurph
Nov 17, 2008 10:54 AM
Trouper
Aug 26, 2008 03:03 PM
CincyDJ
Apr 27, 2006 05:27 PM
