Illegal?
100watt units will run hot and probably melt your housing as well as damage/melt the bulb socket. Higher wattage doesn't make a better bulb, may be a bit brighter but I bet these bulbs have a good blue coating on them with in turn will dim them down a bit. Also hotter bulbs with tinted/painted glass are more likely to burn out (melt the glass and leak out the gass or explode the glass) and provide less useable light than oe bulbs. My buddy had been purchasing "lifetime guarentee bulbs" from Procarparts, one night he had not one but BOTH bulbs blow out in a second of each other right infront of a cop, he said when he took out the bulb it was curled into a finger shape...
The links posted by Kar are good but pointless when the OP was talking about HALOGEN bulbs not HID....
His original post was filled with mis information. standard bulbs are NOT measured in kelvin. period. Xenon bulbs are "look alike" bulbs, NOT true HID's
They are measured in watts. anything above 60 watt's is HOT for high beam. and above 55 for low is in the same area.
He needs to decide what he's talking about.... You can upgrade your standard bulbs with a higher wattage xenon bulb, and have no real problems....other that melting your factory harness. (use a relay and upgrade your cables)
So, see.... my links were not pointless! read carefully my friend!
And Merry Christmas
And Merry Christmas
