keyless entry remote for my civic
Old May 11, 2009 | 06:36 PM
maroon's Avatar
Default keyless entry remote for my civic
i bought a civic but it didnt comes with keyless entry remote,im wondering if my civic has really no keyless entry remote,or if it has how will i know it?
i check ebay and i found one selling a keyless entry remote for model 99-00 civic ex same model with my car. do you think guys this might work?
http://cgi.ebay.com/ebaymotors
/1999-2000-HONDA-CIVIC-KEYLESS-REMOTE-ENTRY-FOB_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2 Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3 a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem 45ec0a4bcbQQitemZ300312841163QQptZMotorsQ5fCarQ5fT ruckQ5fPartsQ5fAccessories
Old May 11, 2009 | 08:58 PM
croninc's Avatar
Yeah you will just have to program it with your car. I had this same problem awhile back. Im going to go dig through some old posts. So in other words yes it will hopefully work, just let me find the post with the instructions on how to program it with your car.
edit: do this
Did you try programming the remote to the car?
turn key to on position
press the lock button on the remote
turn the key off
turn the key on press the lock button on the remote
turn the key off
turn the key on and press the lock button on the remote
turn the key off
turn the key on press the lock button on the remote (by now you should hear the locks cycling which means it is in programming mode)
press the lock button on your other remotes (the car can remember up to three)
also when you do this
make sure both doors are closed
make sure you do this quickly as it won't work if you do it slowly
if you have a 96-98 Civic the factory radio must be installed (this does not apply to 99-00)
Old May 12, 2009 | 11:39 AM
2000Ex's Avatar
I have bought 2 different remotes from ebay and both work slash are working flawlessly. The first one broke when some tard threw my keys up in the air. This one has been going over a year and the batteries are dying but still good.
Old May 12, 2009 | 12:08 PM
for the cost o fjust geting a OEM keyless entry remote you can go ahead and spend some more money and get a alarm with keyless entry. protect your car FTW
Old May 14, 2009 | 08:39 PM
maroon's Avatar
you mean even without the keyless entry i can put an alarm and used them as a keyless entry too?ist it possible,
Old May 15, 2009 | 05:23 AM
yep. as long as the car has power locks you can add any time of aftermarket keyless entry unit. its not plug and play so if your not sure about wiring then have a alarm shop wire up a alarm system.
Old May 17, 2009 | 09:27 AM
maroon's Avatar
how will i check it ,if my car has a power lock?,i really have no idea.my car civic is 2000 ex stick shift
Old May 17, 2009 | 10:38 AM
^ are you serious? power locks... they are either power or manual. you have a EX so it should be loaded power everything.
tlkolrod
Dec 2, 2006 03:39 PM
tlkolrod
aarslank
Aug 14, 2006 11:36 AM
sav127
Jul 24, 2006 10:01 AM
alpha202
Jul 31, 2005 01:50 AM
