keyless entry stopped working
Old Nov 7, 2008 | 10:10 AM
burgernuds's Avatar
Default keyless entry stopped working
hi my viper alarm just stopped working. it will still make the beeping noise and the my parking lights will still blink but the doors won't lock and the alarm does not get armed.
Any ideas on why?
Old Nov 7, 2008 | 10:54 AM
What year Civic?
Is the transmitter working properly?
Can you still lock and unlock the doors using the switch on the driver's door?
Are you able to post a circuit diagram for the alarm system?
Have you checked for blown fuses?
Old Nov 8, 2008 | 01:53 PM
315 Customs's Avatar
if your fuse for the power locks is blown or the plug for the lock harness into the brain of the alarm came out.
Still need all the info Ron asked for in order to be able to tell you for sure because it could be something else too
Old Nov 11, 2008 | 09:35 PM
burgernuds's Avatar
for some reason it worked again this morning...
the other day i tried everything and it didnt work...
maybe something is loose?
Old Nov 11, 2008 | 09:36 PM
burgernuds's Avatar
What year Civic?
2001
yes - car light and alarm still works
yes
no
yes, fuses are good
Old Nov 11, 2008 | 09:37 PM
burgernuds's Avatar
one thing that i remember now is that before the key less entry stopped working (doors wouldnt lock) i opened my door while on the road to check to see if my rear tire was okay, and i used the switch on the drivers door to unlock the door to open it.
Old Nov 11, 2008 | 09:52 PM
The stock keyless remote operates the door locks through the multiplex control unit. For the stock system, I would suggest that you troubleshoot this unit. It's more difficult to say for an aftermarket alarm system in which knowledge of the wiring is unavailable.
Old Nov 18, 2008 | 09:32 PM
Robzilla's Avatar
Was the alarm installed at a shop? Some shops use T-tap connectors which can come loose over time. That could be the case, for it to work sometimes. Was model viper alarm is it? Check the alarm harness and connections. If you need I can look up the color of the lock and unlock wires.
Güero
Jun 24, 2008 08:58 PM
Civicity
Aug 18, 2007 07:53 AM
rmvols31
Apr 24, 2006 10:00 PM
farkus
Nov 24, 2005 08:46 PM
cfauvel
Sep 22, 2005 01:23 PM
